The great return of stringing. Why?
I was able to set my MK2S very well. No stringing, no oozing at all.
Then I moved to another house and now I'm getting a lot of stringing with the same filament spools. See photo https://ibb.co/pwprWTt
Is it possible that the humidity caused this? I was able to print the same model without any stringing!
Napsal : 09/11/2019 5:50 pm
RE: The great return of stringing. Why?
Moisture absorption can definitely contribute to stringing, yes. Also worth confirming that you re-ran the XYZ calibration after the move since the physical parts can get jostled around.
Napsal : 09/11/2019 7:04 pm
1 lidem se líbí
Topic starter
answered:
Yes, I can confirm that was the problem... Thanks!
I had already done calibration.
I dried filaments on a heater for one day and now stringing is widely reduced. In UK the wet weather is a big problem!
Napsal : 11/11/2019 9:21 am
