Random balls on an otherwise good looking print
I have owned the MK2s since release and have never had succesful print. Today I was able to get the z lowered where it looks like its printing ok, but I was getting these weird balls randomly on the print, which I had to take off.
Any ideas what is happening or how to fix?
RE: Random balls on an otherwise good looking print
Material?
Not sure what that crystalized stuff is on your bed. But Live-Z looks low and causing ripples in layer one.
The bits of plastic looks a lot like a mal-assembled hot end. One where the nozzle and heat break are loose in the heater block and leaking.
I am printing ABS. The crystalized stuff is ABS sludge (acetone with ABS melted in it)
My printer came assembled. Did they do something wrong?
The first layer is definitely not correct. It should be one consistent solid layer, not a grid of lines.
Are you always printing ABS? Tried something else? I sugest you should learn how to print with PLA or PETG.
It is then also much easier to help you, this foto shows only a big mess. Also ABS sticks to heated bed with PEI good enough even without ABS sludge.
Milos
@milo-v
Is the nozzle too high or too low? How to I stop those balls from forming?
I only print ABS. If this printer can't do ABS, I might as well throw it in the trash.
ABS has a higher melting point than the alternatives
How old is the printer (MK2's aren't exactly current).
As for the extra drops; have you ever changed the nozzle?
Have you ever done a Live-Z adjustment? If not, time to learn the process.
Here's a calibration target: slice it for ABS and print it, adjust Live-Z as it prints to get a clean, solid sheet of plastic. When it lifts off the bed, there should be no gaps between any of the extrusions. If it comes off like a harp, then you need to go lower (Live-Z more negative).
Here's an image showing the range of layer 1 defects: Too low, the edges show ridges forming between extrusions; Too high, gaps between extrusions; and areas where the layer looks good, a sloid sheet of plastic.
And as Milo is saying; ABS sticks reasonably well to clean PEI. ABS juice or similar extreme treatments are not required normally for parts the size you are printing; though once in a while, hair spray or glustick for small bed area parts.
