Problems with 3DBenchy
Emiliano
(@antonio-d3)
Hello everybody,
as the title of the topic I have difficulty in obtaining a good result in printing the legendary 3DBenchy boat.
I have an Original Prusa i3 MK2S Multimaterial 1 printer, I use PrusaSlicer 2.2.0 and the filament is a grey PLA.
Although I have changed several settings such as retraction, lowering the print temperature, decreasing the speed of both extrusion and travel, I always get the same printing defects: imperfections at the height of the two front holes of the hull, on the rear edges of the hull and the central part of the cabin (photos attached). What do you recommend changing to get a decent print? Thank you in advance 🙂
Napsal : 08/04/2020 10:34 pm
