problems while printing
Jacques Verreault
(@jacques-verreault)
Hi everyone
Does anyone had this code pop up on the MK2 display ( $5592M105 ). When i get this while printing ... the extruder stop dead and i hear it vibrating .... and i have no clog ... it's like extruder can't work anymore and it is very hot. When that happens i usually cancel the print and after a few minute the printer resume, but does free game ( goes all over the place ) and it takes some time to finally stop. By the way ... i print via my computer. What do you think ... is it the X-axis stepper motor or the extruder motor or both.
Opublikowany : 31/07/2018 1:51 am
Re: problems while printing
try printing from SD card, eliminate the computer and usb connection
Opublikowany : 31/07/2018 1:54 am
Jacques Verreault
even when i'm printing via SD card .... I still get that problem
Opublikowany : 31/07/2018 1:59 am
That looks like mangled gcode. I had similar happen when copied gcode had been word-wrapped. Check the gcode file for errors. Search on those strings.
Opublikowany : 31/07/2018 4:01 am
