Print with TPU Flex
arkatcrime
(@arkatcrime)
Print with TPU Flex
Hi guys,
I tried printing with TPU for the first time.
The final result was as follows:
It's normal? I don't like the final look t all 🙁
Publié : 16/04/2020 5:38 pm
Membre
RE: Print with TPU Flex
Retraction is key, but some stringing happens with flexibles.
Publié : 16/04/2020 11:59 pm
arkatcrime
(@arkatcrime)
@charles-h13
How I can minimize stringing?
Publié : 17/04/2020 8:55 am
arkatcrime
(@arkatcrime)
I resolve this with the next parameter:
Filament settings > Filamente Overrides :
"retract on layer change"
Publié : 20/04/2020 8:07 am
Have you dehumidified the filament?
it looks bubbly,
Publié : 20/04/2020 4:17 pm
arkatcrime
(@arkatcrime)
@joantabb
Yes, is dehumidified! The filament is new ! it's ruby color.
But I continue with strings! Someone helps with "retracting" configuration?!
Publié : 23/04/2020 10:21 am
I use 'Generic Flex' but set retractions to 0.0mm
and on small sections, you need lots of cooling!
Publié : 23/04/2020 10:39 am
1 personnes ont aimé
arkatcrime
(@arkatcrime)
@joantabb
can you share your configurations? please!
Publié : 23/04/2020 1:35 pm
Hi Arkatcrime,
I have enclosed a .3MF file for a recent model  (A repair tube for a vacuum cleaner connector, where the original had split..)
I hope this helps.
it is the Generic Flex profile at 0.3mm layer height with retraction set to zero, and the fan set to run above layer3
Attachment removed
Publié : 23/04/2020 5:02 pm
arkatcrime
(@arkatcrime)
@joantabb
I have a doubt.  Your retraction is 0mm (Zero), but  zero you don't disable retraction?
Publié : 23/04/2020 9:49 pm
