Print thin lines
Bob
 Bob
(@bob-2)
Print thin lines
Hi All,
    I've begun importing line drawings into Tinkercad by converting them from JPG to SVG.  For the most part I'm really happy with the results, however when the art work I'm working with have very fine lines some of the lines don't make it past the slicer.  I can bring the STL fils into Prusa Slicer and they look complete, but when I slice it many of the fine lines vanish.
So far to get around this I pull the art into GIMP and thicken some of the missing lines, but this is more work than I want to have to do.  Is there another technique I can use to get these fine lines to print?
Thanks
-Bob
Publié : 10/11/2019 6:28 pm
RE: Print thin lines
Hi Bob,
You could scale the model larger,
you could use a smaller nozzle,
or you could try XY Compensation, which is an 'Expert Mode' feature, in "Print Settings>Advanced"
Publié : 10/11/2019 8:17 pm
