PRINT SLANTED/SKEWED IN Z AXIS HALFWAY THROUGH PRINT
Dear community,
I had this problem recently with my printer: the print started skewing/slanting in Z axis halfway through print. I re calibrated XYZ and it happened again. X and Y is very good but only Z is affected. May I know what is the issue?
Postato : 15/09/2018 10:18 am
Re: PRINT SLANTED/SKEWED IN Z AXIS HALFWAY THROUGH PRINT
That is a shift in X (or possibly Y).
If you are printing in "silent" mode, switch to high power. Check your pulley grub screw, check your belt, slice with Z-lift.
Peter
Postato : 15/09/2018 2:53 pm
