Print quality and slicers
MrObvious
(@mrobvious)
Hi
I am quite new to 3d printing got my Prusa i3 Mk2s kit in July. I have been printing successfully on it since then with some failed prints but I have always managed to figure out why they have failed. I have primarily been slicing in Prusa Control and have had very few issues with it. Recently I wanted to print the self watering planter on thingiverse ( https://www.thingiverse.com/thing:903411 ).
It is recommended to print with three shells to increase water tightness. So I sliced it in Slic3r PE with three shells, 5 bottom layer at 0.3mm layer height. The print succeed however the finished is terrible (it is the right one in the images. To double check my self I then sliced it in Prusa Control and printed it again and it printed really nicely with a loverly finish (the left one in the image).
Just wondered what the difference was and why Slic3r PE would have made such a difference to the finish? Can anyone enlighten me.
Thanks
Opublikowany : 23/09/2018 9:48 pm
Jindřich Beneš
(@jindrich-benes)
Re: Print quality and slicers
Could you please share gcode as well?
Opublikowany : 26/09/2018 7:01 pm
MrObvious
(@mrobvious)
Yes of course, but how do I share it. I tried attaching the file and it did not accept it?
Opublikowany : 02/10/2018 5:19 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Zip it up and attach it to a post.
Peter
Opublikowany : 02/10/2018 5:25 pm
MrObvious
(@mrobvious)
Perfect thank you
The files are attached
Opublikowany : 02/10/2018 8:59 pm
MrObvious
(@mrobvious)
Anyone had a chance shed any light on this for me. I am not confident of using slic3r PE at present because of this issue.
Thanks
Opublikowany : 10/01/2019 4:22 pm
PrusaControl (PC) uses Slic3r under the hood to generate the gcode, but at this point, it's using a very old version that was configured with fairly conservative settings to help inexperienced users get good results. Slic3rPE has been under continuous development, and has been tweaked and tuned for the Prusa hardware considerably since. If you're using a more recent version, it's very likely you'll get slightly different results.
If you want to experiment, you can import the PC-generated gcode into Slic3rPE as a config (via the File->Load config menu option) to load the same settings that were used to generate the gcode into the newer version of Slic3rPE. I did this with the 2 gcode files you uploaded, and there are some notable differences in settings.
Your speeds in Slic3rPE are higher, notably for perimeters. Not by a huge amount, but it may be enough to matter.
Your perimeters are different as you noted.
Poking through other differences, I was really surprised to see these Advanced settings differences:
I hadn't noted PC using those extrusion widths for a 0.40mm nozzle before. I also noted a lot of other minor differences for filament temp and cooling settings.
The lumpy surface on the right-side cylindrical surface might be accounted for by increasing to 3 perimeters and having a bit of over-extrusion. You're using more filament for those walls essentially making them solid and any excess filament has to go somewhere.
Looking at your prints, the differences are mostly around features such as grooves in the surface. You'll see surface variations like that very often corresponding to speed changes layers as the printer has to move the bed and extruder on one layer but not another. Some layers may be shiny, or be under-extruded. This isn't a fault so much as an indication that you need to dial-in your settings. Slow down your speeds and those variations in vertical surfaces tend to fade away and even out. The easiest thing to try would be simply slowing down the print using the front know mid-way through your print using the Sli3rPE-generated gcode. Dial it way back to 50% or so and let it run. Do the results look better and more consistent? If so, dial back your print speeds in Slic3rPE. How far exactly depends on a lot of factors, but you could try knocking say 10% off external perimeter speeds and repeat until you get good results. Or knock 50% off and work upwards.
Don't be afraid to dive in with Slic3rPE. It's definitely different than PC, but you'll soon appreciate the added control. I'd definitely recommend finding some small test pieces that can print in 15-30 minutes rather than larger prints at least until you get close with your settings.
Opublikowany : 10/01/2019 5:30 pm
MrObvious
(@mrobvious)
Thank you that is great. I will carefully read and take in all the information and try again. I have updated my Slic3r install now as well and will try again.
Opublikowany : 10/01/2019 7:10 pm
