Print nGen FLEX on PEI Questions?
Wirlybird
(@wirlybird)
Hi all,
Going to print a larger part using nGen FLEX.  They recommend BuildTak as the surface to use but I am not going to change out the MK2 PEI for that.
Anyone using this on PEI?  I print a lot of PETG on my PEI bed and no issues.
I have printed Hatchbox TPU on the PEI and it stuck pretty good.
Looking for any user experiences with the nGen FLEX material on PEI!
The stuff is a bit pricey so I can't experiment too much!
Thanks.
This topic was modified 7 years ago by Wirlybird
Posted : 02/07/2019 12:52 pm
Dave Avery
(@dave-avery)
RE: Print nGen FLEX on PEI Questions?
i had great luck print TPU with a PEI build plate and a gluestick coating, nice adhesion and easy seperation
Posted : 02/07/2019 3:37 pm
ManelTo
(@manelto)
For flex filament I use talcum powder. Then it's easier take out the objects.
Sorry for my poor English. I try to do my best.
Posted : 03/07/2019 10:52 am
Wirlybird
(@wirlybird)
Ahh, I forgot about that trick!
I am hoping my issue with nGen FLEX will be too much adhesion rather than not enough!
I just finished a bunch of PETG printing so the bed may be good and ready for FLEX.
Thanks.
Posted : 03/07/2019 11:22 am
If your TPU/TPE does stick too well.
Drip some IPA on the cold build plate, let it sit for a short while, then the model should release more easily!
Posted : 03/07/2019 12:53 pm
Wirlybird
(@wirlybird)
Thanks.  I am more concerned about it warping or curling at the edges.  Colorfab recommends a BuildTak surface but that is not practical for me.
This material is expensive and the part is going to be ~300g and a 30 hour print so failure will be costly!!
I assume the idea is for the IPA to get under the edges of the print?  I'll keep this in mind, thank you.
Posted : 03/07/2019 1:24 pm
