Large print brim goes over skirt and peels up with petg
ryan.f15
(@ryan-f15)
I have a pretty large print that I am trying to do, but when it does the skirt, the brim runs over it.  Then it peels up as the head hits.  I went through calibration and the calibration surfaces look fine.  Is there something else I need to do in order to get this to work?
Napsal : 20/02/2021 2:11 pm
RE: Large print brim goes over skirt and peels up with petg
If you're using a brim, you don't need a skirt. I'd disable the skirt. PETG does not require as much 1st layer squish as PLA. Have you tried raising Live-Z (making it less negative)? Raising it by 0.02-0.2mm can help with peeling up 1st layer PETG.
Napsal : 20/02/2021 2:22 pm
ryan.f15
(@ryan-f15)
@bobstro
I tried not brim at all, and what I found was that parts wouldn't stick at all(it's a screwdriver holder) and the holes for the screwdrivers wouldn't adhere to the textured bed in some spots while they would in other areas.
Napsal : 20/02/2021 6:54 pm
towlerg
(@towlerg)
If you need a brim and a draft shield (skirt) and the skirt clips the brim, increase the distance from object.
Napsal : 21/02/2021 10:45 am
ryan.f15
(@ryan-f15)
Well it still isn't working.  3 g-d damn hours with support and no closer to fixing the problem, and I can't even get a level print now.
Napsal : 21/02/2021 9:12 pm
