How print Growlay white at 80-135ºC ?
Hi , I try to print below 135ºC what is the growlay manufacturer recommends, and the printer do not extrude the material
I think that below 180 degrees the extrusion motor stops working
Some help?
Thank you
Opublikowany : 29/06/2019 4:38 pm
Topic starter
answered:
RE: How print Growlay white at 80-135ºC ?
The problem is : PREVENT_COLD_EXTRUSION.
I add to g-coge :
M302 S0 ; always allow extrusion (disable checking)
http://marlinfw.org/docs/gcode/M302.html
Opublikowany : 30/06/2019 3:21 pm
