First layer issues
CraigL
(@craigl)
First layer issues
Hello,
This all started about three months ago when I upgraded to the newest version of the firmware for the Mk2. I was on 3.0.8 until I upgraded to 3.1.0. Anyways, after upgrading I am unable to print because the print will not stick to the bed, it is as if the live Z adjust isn't taking effect on anything other than the V2 calibration. I am able to print the V2 calibration just fine but nothing else. I have tried downgrading the firmware back to 3.0.8 to see if it would fix the issue but it unfortunately did not. I am not sure what else I can do to fix this issue. I use Cura 15.04.6 as my slicer.
Thank you.
Veröffentlicht : 28/08/2018 12:23 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: First layer issues
Try printing one of the pre-sliced models from the SD card.
If it's a problem then upload a photo of the first layer. If it's not a problem, then you know it's the slicer (probably the Start G-code settings).
Peter
Veröffentlicht : 28/08/2018 10:15 am
CraigL
(@craigl)
Peter,
Good call on the slicer settings. I had ruled that out because prior prints weren't working that worked before and I hadn't changed anything. I uninstalled the slicer and reset the profiles and it looks like I am back in business.
Thank you very much!
Veröffentlicht : 29/08/2018 2:19 am
