extrudr Flex Semisoft does not print properly
HNYPT
(@hnypt)
Hey guys,
I want to print some tires from the extudr tpu semisoft. But I have some problems to print it with the prusa i3 mk2. I am using PrusaSlicer and I have tried the Flex Settings before, I didn't worked with the stock settings so I changed some minor settings such as the Extruder Temperatur to 220 [°C] since extrudr want's you to print between 190 - 230 [°C] and the printing speeds down to 25 [mm/s]. The problem is that the Extruder Motor starts to click and stops to print properly. Does anyone has tried the extrudr semisoft with the prusa i3 mk2 and has some tipps for me?
Frederik
Veröffentlicht : 12/12/2019 9:46 am
RE: extrudr Flex Semisoft does not print properly
Hi Frederik
I usually turn retractions off  (0mm) when printing TPU, this may work for you!
Veröffentlicht : 12/12/2019 10:05 am
