Clumping of filament/extruder curling filament (pictures)
george.j2
(@george-j2)
Not sure if there is a name for this particular issue, but, whenever I print two things are happening.
  1. When the filament is loaded, the extruder appears to loop the beginning of the dripped filament (see image below with the cooled filament with a loop).
  2. When printing on the heatbed(live z @ 1.022), the filament seems to stick to the bed at certain points but then starts to rise and form curls when the filament is extruded.
I'm sure the issue is the extruder just not sure how to describe the issue in order to search the forums.
(sorry, I'm not sure why the images are rotating when I upload them)
Dieses Thema wurde geändert Vor 7 years 2 mal von george.j2
Veröffentlicht : 20/06/2019 2:48 pm
RE: Clumping of filament/extruder curling filament (pictures)
Oils on the bed are preventing the filament from sticking.  Do a soap and water wash of the bed and keep fingers away.
Alcohol rinse: every few prints
  • Gloves recommended.
  • Once in a while, an alcohol rinse is helpful to remove PLA residue. It does not remove finger oils well.
  • Pour a 5 cm puddle of 91%+ alcohol in the middle of the bed, with clean hands use a fresh paper towel to scrub the bed. Wipe up all the alcohol.
Acetone wash: infrequent
  • Pour a 2 cm puddle of acetone on the bed, scrub it around with a fresh paper towel. It will evaporate fast as you clean. This step removes PEI oxides that form over time and with heat, and improves PLA adhesion to a like new state.
Hot Water wash: often, as needed, and after any of the above
  • Handle the bed only by the edges.
  • Wash the bed in hot water, use a fresh paper towel as a wash cloth, with a few drops of plain dish soap (Dawn, unscented, no anti-bacterial, etc.).
  • Rinse well in hot water - if you have very soft water, rinse a bit longer.
  • Dry the bed with a fresh paper towel.
  • Place bed on printer.
Streak test: when contamination is suspected
  • With a fresh piece of paper towel, and very clean fingers, dampen the towel with 91%+ alcohol, and wipe the bed side to side moving back to front, like you're painting it with alcohol. The alcohol should be thin enough on the towel it quickly evaporates. If you see any streaks, the bed is dirty and needs a wash.
Diese r Beitrag wurde geändert Vor 7 years von --
Veröffentlicht : 20/06/2019 3:14 pm
Lichtjaeger
(@lichtjaeger)
And do a first layer calibration. Your live Z is way off.
Veröffentlicht : 20/06/2019 4:03 pm
george.j2
(@george-j2)
Thanks for responding.
I tried the hot water wash and after did the alcohol wipe down...I'm still having the same issue.
I'll work on re-adjusting the probe and re-calibrating.
Veröffentlicht : 23/06/2019 10:26 pm
george.j2
(@george-j2)
So, I tried the soap/hot water wash and wiped it down with alcohol. The calibration gets passed without a problem but when I try to print the first layer (calibration), I receive the error in the attached video. This only happens when trying to print something, doesnt happen when i try moving x,y,z axis. Not sure what's going on. Nozzle is clean, no debris on the bed.
Any suggestions?
https://streamable.com/aa444
Diese r Beitrag wurde geändert Vor 7 years von george.j2
Veröffentlicht : 04/07/2019 2:37 am
Dave Avery
(@dave-avery)
it's failing the bed leveling - have you flashed new firmware recently?
  things to try
     rerun selftest
     rerun XYZ calibration
     if either of those have issues  = do a "factory reset with data clear"
     rerun selftest/XYZ calibration
Veröffentlicht : 04/07/2019 3:44 am
I'm hearing a jam or belt hop - make sure your belts are tensioned and not slipping over the pulleys.
Printer moves faster when printing and performing the mesh level. So sticky bearings, tight U-bolts, can create drag that only causes problems at the higher move speeds.
Veröffentlicht : 04/07/2019 6:17 am
Oh - and if you used alcohol AFTER a soap and water wash, go back and wash again in soap and water. Alcohol is very good at taking the oils off your fingers and moving it to the PEI sheet.  The only way to avoid this is to use gloves, or simply use soap and water last.
Veröffentlicht : 05/07/2019 5:59 pm
george.j2
(@george-j2)
So the factory reset and re-test/calibration worked but now there's another issue where the pending print will not stick to the heatbed completely.
When trying to print the Prusa logo, I noticed the far left of the pending print lifts off the heatbed slightly. I'm not sure how to test if the bed is damaged.
The images below show my 3 attempts at printing the prusa logo, in order from top-to-bottom, you will find the 1st-to-final attempt.
https://imgur.com/a/JVl1rMw
I appreciate all the responses and help thus far.
Veröffentlicht : 10/07/2019 1:15 am
