All my smooth surfaces are printing rough - at wits end 🙁
Deb
 Deb
(@deb)
I have been trying to print a simple, flat object for days. It looks smooth and then when I print it the surfaces does this. I cannot figure out what I am doing wrong. I am printing with PLA and the file was created in Blender and then I used slic3r to create the gcode. I have tried everything that has been suggested in blender but nothing is working.
Here is a link to a photo https://www.dropbox.com/sh/a7ex6op0ij595v3/AAAvnRuUr4kemWICeKYO2iPVa?dl=0
Publié : 09/05/2018 3:10 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: All my smooth surfaces are printing rough - at wits end 🙁
Two things
1. Can you please attach your photo directly to the post
2. Can you please try printing the pre-sliced Prusa Logo from the SD card to see if that suffers the same problem.
Peter
Publié : 09/05/2018 9:14 am
Deb
 Deb
(@deb)
Hi Peter,
Here are both of the things you asked for 😀
Publié : 09/05/2018 5:43 pm
zbrozek
(@zbrozek)
Are you using the stock nozzle? Have you measured the diameter of your filament; is very close to 1.75 mm? Have you changed the steps/mm setting away from the default? It looks like you're pushing out too much material somehow.
Publié : 10/05/2018 4:31 am
Deb
 Deb
(@deb)
Yes, it is the nozzle that came with it and the PLA filament also came with it. No, I have not touched the steps 🙂
Publié : 11/05/2018 1:32 am
PJR
 PJR
(@pjr)
But have you measured the filament? If so, what is the average diameter over a 5 metre length?
You will probably have to calibrate the extruder but also ensure that you have the correct tension on the drive pulley.
Peter
Publié : 11/05/2018 1:30 pm
digibluh
(@digibluh)
just to be clear, your over extruding but the surface won't look like the bottom of the print... better than this but still not like the bottom.
Publié : 12/05/2018 8:17 am
