Z Calibration fails
xander.j2
(@xander-j2)
Z Calibration fails
I recently replaced the PEI bed cover on my MK2 but now when I try and calibrate the Z axis, the extruder keeps catching the sheet of paper. I have the probe 0.6mm higher than the extruder itself but it acts as though it's much too high. Also, when I auto-home, it pushes down into the steel plate instead of homing correctly on the Z axis. The Y axis and the X axis are all working correctly but I can't figure out why my Z axis doesn't seem to calibrate correctly. Any ideas?
Opublikowany : 27/02/2020 9:42 pm
