Why is the extruder pulley made of Brass ?
Stránka 2 / 3
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Why is the extruder pulley made of Brass ?
Christian
This:
Is usually caused by having the filament tension too tight.
Peter
Napsal : 08/12/2016 9:37 pm
MrMik
(@mrmik)
The replacement pulley from Prusa is quite pricey at $13.73 .
http://shop.prusa3d.com/en/mk2-spare-parts/126-mk2-extruder-hobbed-pulley.html
I wonder why these cost more than your average pulley.
There seem to be many much cheaper, similar (but only similar) hobbed pulleys on offer in various internet 3D print shops, some even at half the price for stainless steel versions.
Example: https://www.amazon.com/RepRap-Champion-Filament-Printer-Makerbot/dp/B00THZK97I/ref=pd_sbs_328_t_2?_encoding=UTF8&psc=1&refRID=M9862PDH5QT4T7D1A4JK
Napsal : 10/12/2016 11:42 pm
PJR
 PJR
(@pjr)
Yeah, but its the size that matters.
The Prusa pulley is slightly smaller than the SS ones you will find online (6.2mm vs. 7.5mm) and this causes alignment and feed issues (the latter can be corrected in firmware/GCode but the former requires a redesign of the extruder body).
I did find a cheaper alternative at Oozenest, but it is brass: http://ooznest.co.uk/3D-Printer-Mechanical-Parts/Belts-Pulleys/Hobbed-Pulley .
Peter
Napsal : 11/12/2016 10:21 am
MrMik
(@mrmik)
Peter
Aha, at least an alternative (if it fits, of which I am not quite sure how to tell...).
I've bitten the bullet and ordered 2 from Prusa, and a PINDA probe.
Napsal : 11/12/2016 10:30 am
PJR
 PJR
(@pjr)
Tech Specs:
Small 5mm Bore
Material Brass
Bore Diameter 5mm
Hobbed Diameter 6mm
Outer Diameter 8mm
Length 13mm
Peter
Napsal : 11/12/2016 10:34 am
dennis.s6
(@dennis-s6)
I was going to order a replacement plus a spare from prusa but the cheapest shipping was $55.00!
This should be a mk8 or something else easily sourced. Why use parts that are impossible to find when this machine is supposed to be "open source" design?
Napsal : 31/01/2017 10:00 pm
JeffJordan
(@jeffjordan)
Member Moderator
... but the former requires a redesign of the extruder body.
❓ anyone here who could alter the extruder body, so that a commonly used MK7 drive gear (steel) will fit ?
Napsal : 31/01/2017 10:20 pm
Hi Jeff,
that would open up other issues, for example changing the steps per mm...
the mk7 is a lot bigger than the prusa so your definition would suffer.
a better bet would be to use the mk8 hobbed wheel, which is closed to the prusa hobbed wheel, you would still have to chang the steps per mm, but the definition would be better.... (not as good as a working prusa hobbed wheel...
another option may be, to find someone who can make a stainless hobbed wheel to the prusa dimentions.
or to get a prusa hobbed wheel plated...
Napsal : 31/01/2017 11:33 pm
Modifying the plastics, might lead to the extruder plastics colliding with the chassis at extreeme ends of travel.
Napsal : 31/01/2017 11:35 pm
JJ3DPrinter
(@jj3dprinter)
I have a probably 20 feet of 1" round 17-4 stainless steel from past projects I've had manufactured. Being that I'm somewhat near the biggest industrial park in the USA it might be worth it for me to find out how much it would cost to machine up a bunch of these extruders hobbed gears. If we had enough people I'm sure I could get it under $25 for the part. Around here machine rates are typically around $100 an hour + 0.5-1 hour for machine setup. If there's interest post here.
Napsal : 01/02/2017 2:54 am
With respect, if you were considering making parts... I would suggest that you keep the one inch round material for another project, and buy in some stock nearer the actual required size. because the machine time to reduce the dimensions would probably massively outweigh the cost of the new material.
Napsal : 01/02/2017 11:39 am
MrMik
(@mrmik)
I would certainly buy a hobbed pulley for $25.- if it was made from steel that will likely last for the life of the printer .
Napsal : 01/02/2017 1:28 pm
Marc
 Marc
(@marc-9)
Unfortunately I don't remember where I saw it (too many videos in my youtube chronicles...) but somewhere Josef mentioned that they will be using a different and quite pricey pulley in the multimaterial add-ons. Maybe somebody from the Prusa team can link us to where they are available...
Napsal : 01/02/2017 2:41 pm
richard.l
(@richard-l)
Member Moderator
Marc
They are going to be using BondTech drive gears. Unfortunately they won't work with the MK2 without the MultiMaterial setup.
http://shop.bondtech.se/ec/drivegears/
Napsal : 01/02/2017 5:15 pm
JJ3DPrinter
(@jj3dprinter)
You'd be absolutely correct. I just checked and the material cost would only be about $1 each. It all comes down to machine time use being split among multiple pieces making them significantly cheaper than doing only a few.
Napsal : 01/02/2017 7:36 pm
Marc
 Marc
(@marc-9)
Thanks Richard for the link.
...pitty... 😥
Napsal : 02/02/2017 1:30 pm
James DeBriyn
(@james-debriyn)
I would be in for a SS pulley that can be sourced in the USA.
Napsal : 02/02/2017 4:39 pm
Clive
(@clive)
So this one does not fit ?
http://e3d-online.com/Extruders/Hobb-Goblin-5mm
There is no valid alternitive somewhere ?
E3d seem to think it'll work, this was their reply when I asked about it;
"This will fit, however the effective drive diameter may differ slightly. You will need to re calibrate your e-steps, but other wise it is just a drop in replacement with no firmware changes or the like needed."
It's a shame they don't have any stock.
Napsal : 06/02/2017 11:49 pm
Clive
(@clive)
Peter
I just received a few of these from Oozenest, they came with a bunch of set screws and an allen key. I asked for extra set screws, so I'm not sure how many they usually pack, but each of mine has 8 or so set screws included.
Napsal : 08/02/2017 5:13 am
Simmer65
(@simmer65)
I stripped the threads on my brass pulley during my first build. One fix that worked (temporarily) was to drill and tap a new M3-0.5 hole on the opposite side from the existing stripped hole. I reinstalled the pulley using the set screw in the new hole and applying medium strength thread locker to the set screw. This worked for one day and then the set screw stripped itself out again. I found the set screw inside the extruder with the new threads stripped again.
I have ordered the stainless steel replacements. When they come in, I plan on turning down the hobbed radius on a lathe for the proper diameter and then cutting grooves in the new "gear" surface with and end mill.
Napsal : 17/02/2017 6:00 pm
Stránka 2 / 3
