Volcano 0.6mm Noz stringing problem
John
 John
(@john-18)
I've upgraded to the E3D volcano eruption
Road so far:
  • Complications compiling firmware, LCD not displaying correctly.
  • Calibration: Cannot locate heatbed during XYZ calibration
  • Heat
With my dimensional accuracy @ +/-0.1mm I can see the light at the end of the tunnel but, i'm at a roadblock with stringing. Next steps before finally getting it functional is stringing.
I've downloaded the economical stringing test from thingiverse (Ultrafast_and_economical_stringing_test) as well as use bobstro's multi extruder.3mf. But i still can't lock down the correct settings could I please get some guidance.
Printer:
  • Prusa I3 MK2
  • Volcano Eruption 0.6mm nozzle / 0.2mm height / 0.65mm layer width
  • eSun PLA+
  • 1.0 extrusion multiplier
Attempts:
Photos to be added, they seem random but they aren't just some . I've kept tabs via a OneNote table and have highlighted results in that produced the best stringing results thus far.
Would really appreciate any help on this.
K=30, Temperature tower using original 0.4mm
K=18
0.2mm layer height
0.65mm layer width
Napsal : 05/05/2020 12:10 pm
