Upgrade quastion MK2s to MK2.5
Craemer85
(@craemer85)
Hello Everyone,
I ruined my bed on my mk2s after trying to peel off a piece of petg. No worries the bed was already well used after more then 3 years of moderate use.
As prusa does not sell the upgrade kit to a 2.5 anymore I ordered one on AliExpress. Since I am not able to print any more I had the following question:
Can I just replace the bed and pinda sensor, upgrade the firmware to 2.5, calibrate and resume printing, or do I need to follow the entire update process (and print all the parts including the parts for the extruder).
Publié : 01/04/2022 7:04 am
RE: Upgrade quastion MK2s to MK2.5
I have a Mk2 with MMU1 which is not supported by the Mk52 12 volt heatbed upgtade,
If I go Mk2.5 Firmware, I believe the MMU1 will not work.
so I literally just changed the heatbed.
I know XYZ Calibration will not work. so I don't try it...
the printer works fine,
If you try this, you could then print the new parts and  complete the upgrade to Mk2.5 if you wish
Publié : 01/04/2022 7:36 am
Craemer85
(@craemer85)
Hi Joan,
Thanks for your quick answer, did you also replace the pinda sensor?
Publié : 01/04/2022 8:06 am
Clemens M.
(@clemens-m)
I don´t think so because the Pinda changes from MK2S to MK2.5 - I think the new sensor ist temperature compensated - any way it has one contact more and so it needs a Y-cable to be able to connect it to the board. Doing this it would be necessary to flash firmware and then your problems will start.
So: change the heatbed to a MK52 12V version and don´t change firmware and Pinda (and you will not be able to do the x, y, z calibration which should´nt be necessary as you didn´t change the printer frame. Be careful and look always to habe a steelsheet on the heatbed as it is not for sure, that pinda will catch the right posission for the magnet (side front, left) - so Pinda will need the steelsheet instead of the magnet.
Best regards, Clemens
Publié : 01/04/2022 8:27 am
no I didn't change the Pinda!
New Mk3s+  pinda's have reverted to three wire non temperature compensated versions...
Publié : 01/04/2022 2:09 pm
