Unresponsive LCD unit
Kraut55
(@kraut55)
My hotend output plug had melted so I disconnected everything to get better access to the board and replaced both the hotend and heatbed plugs.
After I had reconnected everything and started my MK2S the temperature of the nozzle went to 260° and then went down again. The LCD unit was no longer responsive. I switched the printer off and on again, pressed the reset button but was unable to get to any other menu item but the info screen. The screen says no SD card even though I inserted one
I assume I either made a wrong connection (although I checked everything again) or I must have screwed up something during soldering.
Posted : 26/05/2019 6:55 pm
