Thermistor screw
bcheck555
(@bcheck555)
Thermistor screw
Anyone know the size of the set screw that holds the thermistor in the extruder block? Just found that mine is missing, which would explain my seemingly random thermal runaway issues. Thanks in advance.
Opublikowany : 18/12/2016 3:25 am
bcheck555
(@bcheck555)
Re: Thermistor screw
The set screw or grub screw size is m3x3mm per the E3D documentation. An m3x4mm works as well.
http://wiki.e3d-online.com/wiki/E3D-v6_Assembly#What.27s_in_the_box
Opublikowany : 18/12/2016 2:50 pm
