Temperature consistently too low when machine is capable of more
Take a look at this screenshot:
The printer seems to be consistently running 10 degrees too cold. At 260 degrees it ran at about 250. Then, to see what would happen, I bumped it up to 270 and it ran at 260!!
So if it was capable at running at 260, why didn't it do that before? I don't want to configure all my prints hot just so that it fails by the right amount and ends up at the right temperature.
To make sure the PID is ok, I've tuned PID values for 260 degrees using g-code 301 like:
M303 E0 S260 C8
And put the values that came from it into M301
Opublikowany : 02/04/2018 11:02 pm
