slic3r 1.39.1 - z cut function limitation in height
Hey!
I can see that Slic3r comes with a built in function called "cut.." which can be accessed directly from the home screen.
I assume that this function can be used to cut the modelin half or in any user defined z-height.
However I'm only capable of moving the cut section to max 18,8 mm above bed.
Am I during something wrong or have I misunderstood this function?
Do I have to use another software to cut the STL i two pieces?
I'm running
Slic3r Prusa Edition
Version: 1.39.1-prusa3d
Build: Slic3r-1.39.1-prusa3d-full-201803010854
Thanks in advance!
Regards
Peter
Publié : 16/04/2018 8:25 pm
