SD Card Read Failure after update
flyalan
(@flyalan)
I just updated my I3 MK2 to the newest firmware.  All was fine just prior to the update.
Now when I insert the SD Card it shows card inserted but on the SD card menu it shows  "NO SD Card".
I tried doing a complete factory reset. No luck.
Backed the firmware to 3.1.0 and still no luck.  I have used the same card in my MK3 without issue and also tried another SD Card.
Any thoughts?
Cheers
Alan
Opublikowany : 28/03/2020 12:45 am
DJ
 DJ
(@dj-6)
RE: SD Card Read Failure after update
Might not be related but some folks have had success with pushing the SD card all the way in and then pulling it out about 1 - 2 mm. It seems some SD sockets become finicky over time.  YMMV
DJ
Opublikowany : 28/03/2020 3:17 pm
Posted by: @alan-b7
Any thoughts?
Cheers
Alan
Maybe it helps when you reformat the SD-card? It may also be that the SD slot has a loose contact or is defective.
Opublikowany : 28/03/2020 3:49 pm
flyalan
(@flyalan)
since I have tried several cards that all work fine in my MK3 I am leaning toward a coincidental failure of the SD card connections.
Thanks
Alan
Opublikowany : 28/03/2020 4:28 pm
