Replacement bearings recommendation
Seite 7 / 9
LDoubleE
(@ldoublee)
Re: Replacement bearings recommendation
Just fitted some RJ4JP-01-08 igus bearings to my mk2s and now circles come out oval. Any ideas why? Belts and pulleys seems tight.
Igus bearings are less forgiving than the metal bearings, Y-axis rods must be perfectly parallel and the bearing cannot be over-tightened. But, if they are installed properly, they make the printer very quiet.
Thanks. I have a feeling it's due to the x-axis. Y runs very smooth
Veröffentlicht : 12/07/2017 1:43 am
cory.w
(@cory-w)
I just installed these myself. Definitely noticed over tightening makes them worse. What did you use? I did zipties and Mk2s U brackets. Just felt repeatedly tested them throughout tightening process. My rods are slightly scratched from old metal bearings so that may be an issue as well.
Veröffentlicht : 12/07/2017 1:47 am
LDoubleE
(@ldoublee)
I used zip ties for the x carriage and these for the bed https://www.thingiverse.com/thing:1848700
Veröffentlicht : 12/07/2017 1:51 am
cory.w
(@cory-w)
Anyone have recommendations for rods with the igus RJ4JP bearings? The stock ones seem to work but I think they are scratched from old bearings. Igus sells them on website but its more of a pain since im in the US.
Veröffentlicht : 12/07/2017 9:23 pm
harryg
(@harryg)
[/quote]
[/quote]
I use this https://www.thingiverse.com/thing:1846705 for the x-axis and use zip ties just to the point that they don't move. Do not tighten them up or they will definitely bind. You can add a little light oil the rods.
Veröffentlicht : 13/07/2017 1:37 am
harryg
(@harryg)
Lots of users including myself get them from Misumi, PSFG8-370, https://us.misumi-ec.com/vona2/detail/110302634310/?HissuCode=PSFG8-%5B20-800%2F1%5D&PNSearch=PSFG8-370&CategorySpec=00000028943%3A%3A370&KWSearch=PSFG8-370&Keyword=PSFG8-370&searchFlow=results2products&Keyword=PSFG8-370
Veröffentlicht : 13/07/2017 1:42 am
Padnik
(@padnik)
Although they will not fit in the X or Z carriages, I believe it will be fine for the Y bed frame.
I have to correct you on this. My prusa runs on RJZM-01-08 on both X and Y carriages without a glitch and without modifications.
Sorry to bring up the post again, but as the MK2S has U-Bolts to hold the bearings, do the RJZM-01-08 also fit? Its only 1mm difference against the normal RJ4JP-01-08 Bearings, but i am not sure if the RJZM will fit.
Veröffentlicht : 13/09/2017 9:19 am
spark
(@spark)
I am running RJZM-01-08 for bed bearings. The U-thing has a radius of 16mm so it is a tight fit but works fine as I accidentally bought these. I would however not recommended the 01s as you will loose 3mm vertical build. Instead, the right bearing as recommended by IGUS is RJZM-02-08 which is a drop-in replacement for stock LM8UU linear bearings that came with the the MK2 and MK2S.
Specs for your enjoyment.
Stock LM8UU ID 8mm, OD 15mm, Length 24 mm
MK2S kit owner since 8/15/2017
Veröffentlicht : 13/09/2017 1:10 pm
gregsaun
(@gregsaun)
Be careful, on the igus site they specify that the bearing needs a steel housing in H7 or K7 in aluminum. This means it is not a compatible replacement as you need to add housing.
Bear Upgrade Frame for Prusa
--- thingiverse.com/pekcitron --- patreon.com/gregsaun --- ekunn.com
Veröffentlicht : 09/10/2017 5:48 pm
spark
(@spark)
@Greg
You are absolutely right, I've confirmed with IGUS that RJZM-02 does require a housing while the larger RJZM-01 does not. As RJZM-01 is 1mm too large in OD, IGUS has kindly offered to provide me with sample units to test and report for you all.
Veröffentlicht : 09/10/2017 11:46 pm
Knickohr
(@knickohr)
Mitglied Moderator
Confimed too 😉
Use the 02 only with a housing, for example it fits good in the x-end idlers (z-Axis). There are some modifications on thingiverse to fit the igus very well.
Example : https://www.thingiverse.com/thing:2368502
I cannot confirm the 3mm lost in height, there is enough space left for full build volume.
Thomas
Veröffentlicht : 10/10/2017 9:03 am
spark
(@spark)
I used 01 on Y-Axis because it made the most noise and no mod was required. You can make a rough calculation based on cord (gap) and diameter OD of bearing with loss of only 0.65 mm height from print volume going from 15 to 16mm diameter. But this is assuming perfect dimensions. h = 1/4 d sqrt(-(g^2 - 4 d^2)/d^2). Slot of 10mm being g in the equation. In the real world, the Y-carriage slot is smaller, and OD of bearing is slightly larger can be close to 1mm height loss. Where I lost the other 2mm is a mystery.
Veröffentlicht : 10/10/2017 12:24 pm
Knickohr
(@knickohr)
Mitglied Moderator
Yes correct, thats theory.
I can go up to 204mm in z-axis.
Maybe your nozzle is too deep ?
Thomas
Veröffentlicht : 10/10/2017 2:05 pm
spark
(@spark)
I have completed my assessment of All IGUS bearings that have been considered viable by many on this forum. I want to thank IGUS for providing a set of all bearings listed below and am only saddened the results were not flattering to them. But, it is better to know and accept the trade offs than believe your own bias or print inferior parts due to misguided assumptions. As it is quite a chore to replace bearings central to operation of a 3D printer, I hope armed with the information here, you can avoid and or commit to such work for your modding queue.
LMUU8
  • Shell: Steel shell, very strong, resists metal pinching well, prone to rust
  • Housing: Not needed
  • Fit: MK2/s was designed around these so yes it does
  • Noise: 20 dB above ambient
  • Motion: grinding vibration, slight notchiness from imperfections in rod or bearings, but consistent friction on direction change
  • Slop: nearly none
  • RJZM-01-08
  • Shell: Completely resistant to compression (increased friction due to pinching)
  • Housing: Not required nor recommended, very robust shell
  • Fit: 1mm Ø too large, X and Z axis may need mod prints, Z works on Mk2s without mod with loss of ~1mm build height
  • Noise: 4 dB above ambient
  • Motion: smooth but can feel imperfections in rod, very little to no friction in direction change
  • Slop: very little (~0.1mm perp-axis rotation), but not as good as LMUU8 stock
  • RJZM-02-08
  • Shell: Very resistant to compression, tested in Y-U fixture enough strip and did not deform
  • Housing: Recommended by mfg, completely unnecessary for Mk2 or Mk2s application, nearly as strong as 01
  • Fit: Drop in replacement for all
  • Noise: 3 dB above ambient
  • Motion: incredibly smooth motion, noticeable catching on direction change
  • Slop: Completely unacceptable, would cause near mm inaccuracy in prints as bed wobbles ~1mm on X-axis.
  • DO NOT USE
  • RJ4JP-01-08
  • Shell: Can be compressed to reduce slop, can be damaged by too much
  • Housing: Unnecessary for 3D printer use but note Durability
  • Fit: Perfect as 02
  • Noise: 7 dB above ambient
  • Motion: same as 01 in linear motion but catches on direction change like 02, so worst of both
  • Slop: slightly more slop than 01 (~0.2mm)
  • I hope this rests the myths and assumptions about IGUS bearing use in 3D printers. They are meant for CNC and other industrial applications where resistance to debris and long service life without lubrication is required. Silent operation is a side benefit from these traits and are not intended to be used in micron level precision movements necessary for FDM 3D printers. So, if you must sleep near you MK2/s, take the time and print 16mm adapted parts for the RJZM-01-08. But no, I cannot recommend either the RJZM-02-08 or RJ4JP-01-08 because you've just thrown your best-in-class printing quality out the window for a quiet machine.
    Veröffentlicht : 17/10/2017 12:59 pm
    MTJC
     MTJC
    (@mtjc)
    Nice one Steven! Very much appreciated! 🙂
    Any chance you could show us the difference in print quality please?
    Veröffentlicht : 17/10/2017 1:29 pm
    spark
    (@spark)
    I've corrected the wording, no print tests were done. Report was gleaned from bed assembly only. Friction tests were by hand, sound was with a dB meter, slop was determined by yaw twist and digital calipers on fully reassembled printer for each bearing set. Print test would have been ideal but given the slop, I just lost interest when thoroughly disappointed with what I found. When I recover some piss and vinegar, we'll see a quartet of benchys.
    Veröffentlicht : 17/10/2017 3:38 pm
    MTJC
     MTJC
    (@mtjc)
    Oh I see. Thanks for clarifying.
    Veröffentlicht : 17/10/2017 8:38 pm
    your.o
    (@your-o)
    Hmmm. It seems that the others have posted a lot of bearing sources already. This one can serve as reference as well: metal machining services.
    Although the downside on their bearings is it does not have any specs on it. I think it's modified to your needs, so you have to contact them for your desired specs, and would likely go the same way for your rods.
    Veröffentlicht : 25/10/2017 1:03 pm
    Oggie
    (@oggie)
    so anyone ordered the misumi bearings have them shipped to Canada? It looks like it'll costs $30 just for shipping alone.
    And did anyone install them in an mk2s?
    Veröffentlicht : 25/10/2017 7:46 pm
    spark
    (@spark)
    @gary
    It couldn't cost that much from US to Canada.
    @anyone with SKF
    So I want to find out what the deal is with SKF and why they are so much more expensive. Misumi's seem to be smooth as butter from what I've seen online for Prusai...Pruseses? Whatever, clones and or Original but are still not silent. Are SKF any better at reducing noise while retaining glide performance?
    Veröffentlicht : 26/10/2017 2:24 am
    Seite 7 / 9
