PTFE Tubing Left
So, I am trying to replace the hotend and i ordered replacement tubing from Prusa. To me it seems short. My understanding is that it is supposed to stick out about 1mm from the extruder end and then meet the hot end so it can seal. Mine is nowhere close to that. Am I wrong on the length is it okay for the tubing to end somewhere in the heatsink?
Postato : 25/05/2018 7:38 pm
Re: PTFE Tubing Left
If you still have the old hotend that is being replaced you could probably reuse the PTFE tubing from it. Or you could just disassemble the old one and compare the two PTFE tubes.
Postato : 26/05/2018 6:03 am
