Prusa Firmware compiling error
michael.k72
(@michael-k72)
Hello,
i tried to compile the Prusa MK2S 3.1.0 Firmware manually.
I downloaded the Arduino IDE and the Source Code form Prusa.
The first time everything was working, but after that all i get after updating is:
avrdude.exe: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.01s avrdude.exe: Device signature = 0x1e9801 (probably m2560) avrdude.exe: reading input file "./fw.hex" avrdude.exe: input file ./fw.hex auto detected as Intel Hex avrdude.exe: writing flash (251074 bytes): Writing | ################################################## | 100% 42.13s avrdude.exe: 251074 bytes of flash written avrdude.exe: verifying flash memory against ./fw.hex: avrdude.exe: load data flash data from input file ./fw.hex: avrdude.exe: input file ./fw.hex auto detected as Intel Hex avrdude.exe: input file ./fw.hex contains 251074 bytes avrdude.exe: reading on-chip flash data: Reading | ################################################## | 100% 30.25s avrdude.exe: verifying ... avrdude.exe: verification error, first mismatch at byte 0x3c000 0x00 != 0x08 avrdude.exe: verification error; content mismatch avrdude.exe done. Thank you.
I try to change the motor current, because i want to test some motors, so i first tried M907 command with octoprint and everything was fine.
I hope somebody can compile the Prusa Firmware with this parameter in Configuration_prusa.h for me, or can help me to do it by myself:
#define DEFAULT_PWM_MOTOR_CURRENT {500, 990, 500} // {XY,Z,E}
#define DEFAULT_PWM_MOTOR_CURRENT_LOUD {700, 1500, 700} // {XY,Z,E}
Best Regards
Napsal : 22/05/2018 10:17 pm
zbrozek
(@zbrozek)
Re: Prusa Firmware compiling error
That's not a compile error, that's a flash error. Are you sure you compiled for the correct part number of CPU? It's possible that the image you're trying to burn is too big.
Napsal : 27/05/2018 5:05 am
michael.k72
(@michael-k72)
Thank you for your answer.
I think I always used the right file, but after flashing, the LCD only shows white squares and only works again after I flashed the original FW
Napsal : 02/06/2018 6:22 pm
BillC
(@billc)
Michael,
For future use you really need to consider Sasha's question. Do you have a Rambo10 or 13 board? Did you download the correct version of the firmware to match that board?
Small detail but very important.
Cheers,
Bill
Tagaytay City, Philippines
Napsal : 03/06/2018 6:35 pm
michael.k72
(@michael-k72)
Michael,
Cheers,
Yeah, i think so.
Rambo13
okay, next weekend, i will try that again and post the results
Thank you
Napsal : 03/06/2018 9:50 pm
zbrozek
(@zbrozek)
What steps did you use to compile, and what Configuration_prusa.h did you use? I assume you used the Arduino IDE. Under tools->boards, what did you select?
Napsal : 04/06/2018 3:27 am
