Problem with Z axis alignment
Hello all,
After a failed print that got caught by the nozzle and dragged on the print bed, I'm having problems with the Z axis of my MK2S.
When I move the Z axis all the way up, the right side is always lower by 2mm than the left side. This causes the pre-print calibration to fail on calibration point 4.
I've tried to move the Z axis all the way up and force it to colide with the stopers, but when I lower it the right side lowers more than the left.
Already did Z calibration from the firmware and XYZ calibration but the problem persists.
Is a problem with the motor? Is it a firmware issue? I'm running the latest firmware from Prusa.
Any help will be apreciated.
Thanks in advance.
Carlos
Veröffentlicht : 22/12/2023 6:45 pm
