Printer fails on pre-heating
ozboofhead
(@ozboofhead)
Prusa MK2
Do the pre-heat for say PLA and the display shows the bed and print head start to heat up
After a short period the display disappears, and the fan on the print head stop - it basically is dead
Any feedback or ideas on what is causing this and the possible fix?
Cheers
David
Postato : 05/05/2021 9:55 am
RE: Printer fails on pre-heating
Probable power fail for one of a dozen reasons. Start eliminating possible causes. Fix the one you find that is causing the shutdown.
What you are asking is for someone to use remote viewing to diagnose an electronic problem from 1,000 miles away, with a blindfold.
Common issues are shorts in the heaters, power supply failure, thermistor failure, Rambo failure, loose wire, bad stepper, etc. Find the schematics, a good DMM, and start measuring things.
Questo post è stato modificato 5 years fa da --
Postato : 06/05/2021 6:25 am
