[Gelöst] Printer doesn't calibrate points 3, 6 and 9
L.goras
(@l-goras)
As the title says, the printer seems to believe that the points to the very right of the table are higher up than the remaining 6 points, and wont calibrate them cause it doesn't ever find them.
I have tried factory reseting all data but it doesn't change anything. It calibrates the points in the center row and to the left but when it gets to any point on the right row it goes way above the table and searches for several minutes, then stops, saying calibration failed or statis memory overwritten.
Is this a known issue with a fix or is my printer screwed?
Best Answer by L.goras:
Forgot about this thread, however support helped me solve this issue.
The cables to the pinda probe were loose or disconnected in some way, I changed cables to the pinda probe, resolded, and now it works.
Hope this helps others with this same problem!
Veröffentlicht : 08/05/2022 11:47 am
Tim
 Tim
(@tim-6)
RE: Printer doesn't calibrate points 3, 6 and 9
Have you done a Z axis calibration? Usually this works for me when I have this issue.
Veröffentlicht : 04/09/2022 6:39 am
Jan
 Jan
(@jan-7)
Got the same problem. On points 3, 6 and 9 the printhead goes up and immediately goes to next calibration point (except point 9 off course).
I am on latest firmware. Did al the previous calibration. Did a factory reset.
Veröffentlicht : 21/12/2022 12:08 pm
L.goras
(@l-goras)
Veröffentlicht : 23/12/2022 12:10 pm
Jan
 Jan
(@jan-7)
Thanks for answering!
The red light on the pinda is on continously so a loose connection is not the reason in my case. Will try the resolder anyway.
Ill get in touch with support!
Veröffentlicht : 23/12/2022 6:09 pm
