Need to fix headbed, soldered wires broke
Hey! Does anyone happen to know if there is a replacement part I can get, or the best way to fix my heatbed issue. The bed stopped heating, and when i checked the wires it appears that the ground on the heatbed had broken.
I can probably strip and re-solder the wires, but if there's a new wire harness that might be better as i don't know if making the wires shorter will damage things.
Thanks,
Chris
Postato : 26/05/2021 8:38 pm
RE: Need to fix headbed, soldered wires broke
Log into your Prusa shop account and you will be able to access a complete range of spares that are not available otherwise.
Postato : 26/05/2021 10:52 pm
