Need to adjust z more before each print - Drifting z height
sebastiaan.v2
(@sebastiaan-v2)
Never had issues with my printer untill I recently transported it.
Since then I need to adjust z (live Z adjustment") before each print.
So if I do a fresh xyz calibration z is on 0.
At first print I need to live adjust to -0.05 for example. Next print I need to further adjust to for example -0.12 etc etc till after 10 prints I even end up -1.20
My pinda probe is not loose! It's still tightly at the same position.
Any idea what is going on and how to fix?
Respondido : 31/05/2018 9:25 am
BillC
(@billc)
Re: Need to adjust z more before each print - Drifting z height
Unless you run either the first layer calibration or an alternative calibration file then your 'adjustments' are not being saved between prints.
It's a common mistake.
Bill
Tagaytay City, Philippines
Respondido : 31/05/2018 2:07 pm
