need name of electronic part
Kraut55
(@kraut55)
My heatbed plug and with it part of the little black box (connector?) had melted. After a provisional solution I want to use the correct things now.
I bought the plugs already and need to know what the name of the male part is.
Postato : 16/04/2019 3:32 pm
Utenti
Re: need name of electronic part
Is that a terminal header?
Postato : 16/04/2019 3:51 pm
Kraut55
(@kraut55)
That's it. Found the part on ebay.
Thank you very much.
Postato : 16/04/2019 4:03 pm
Utenti
No problem. Glad to be of service.
Postato : 17/04/2019 1:03 am
richard.l
(@richard-l)
Utenti Moderator
You would be better served by removing the header, cleaning the contact area and soldering the wires directly to the board. Once it has failed there is a better than good chance it will fail the same way again.
Postato : 17/04/2019 3:00 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Personally, I would leave the header in place and solder tails to the underside of the board. Less likely to damage the traces.
Peter
Postato : 18/04/2019 11:37 am
