Need Help around broken thermistor / heat block replacement
spacebed
(@spacebed)
Hello!
I've read through several threads around this issue, but didn't see any solutions around the issues I'm seeing with a printer I was "gifted" from an old job I had. The printer itself is a Prusa i3 MK2; and I'm almost certain I know the issue, but wanted to see what folks on this forum thought, or if I'm missing something.
While trying to clean a clog, a co-worker broke what I believe was the thermistor wire, directly on the heatblock. Considering this was our backup printer, they let me take it home, and if I could get it working, I could keep it. Score!
The error I'm seeing is the Error: MINTEMP, and from what I've read on this board, is caused by a broken thermistor.
The fix though, I'm not totally clear on. I've watched videos on how to replace a thermistor, which seems straightforward enough. However, I'm not certain how to get the current thermistor probe out of the heatblock, or if that's even the right approach. Any and all suggestions or direction would be super helpful! Is it possible to remove the thermistor probe from the current heat block f the wires broke directly at the heatblock? Do I need to replace the entire heatblock? If so, which parts would be needed for that? Also, I see a lot of places where I can order a replacement thermistor for an MK2, so I was curious what some reputable sites were, as Prusa does not have one available right now.
Thanks!!
Also, some links to the fullsize images if they look distorted. I tried to scale down a bit for this board.
The broken wire and where it connects below it. I believe it's the thermistor. But, if you look closely, there are technically 2 wires broken which used to go into the same hole in the heatblock. Wanted to make sure I'm not missing anything
The wire to the left broken, the blue shield wrapping that was on it, and what I think is the place where the thermistor connects, below the bare wire. Not the most helpful probably, but wanted to include it for clarity if it helps.
This topic was modified 6 years ago by spacebed
Posted : 16/05/2020 4:02 am
RE: Need Help around broken thermistor / heat block replacement
 You will need to unscrew a tiny grub screw which is embedded inside the Muck on the heatbreak, You might need to heat it up to soften the plastic, if the hotend is still in the printer you may get away with pressing a hot soldering iron against the grub screw hole for about 5 minutes, or until the waste filament on the heater block melts.
As luck would have it, the Knowledge base article is based  on a mk2...      ok a slightly less well used mk2... but that makes seeing what to do, easier...
https://help.prusa3d.com/en/guide/how-to-replace-thermistor-in-the-extruder_22208
is there a serial number sticker on the frame?
If you need Prusa parts, you need to be registered with a prusa account showing ownership of the printer,
Have a word  with the chat helpdesk and hopefully they will transfer the printer to your name.
You may need a new heatblock heater and thermistor, if the thermistor proves difficult to remove  these are available from e3D online, or their resellers,  or on ebay  etc.
the thermistor is a 100K Semitec thermistor in a metal sleeve. the Bead type thermistors were only used on the Mk1 printer, and clones.
Posted : 16/05/2020 3:39 pm
sam.s
(@sam-s)
getting the thermistor and heater out of the block usually ends up with one or both damaged.  the easiest item is to just order new heat block, heater and thermistor as joan suggested.
i've used https://www.filastruder.com/ for many e3d parts since i live in the US.
sams
Posted : 30/05/2020 7:55 pm
Posted by: @sam-s
Seconding this recommendation, at least for your 1st swap. I've added a silicone sock and applied Slice Engineering's boron nitride paste to the thermistor and heater cartridge to aid replacement. Still, having spares of parts with thin brittle wires is a good idea. A spare heatbreak is also a good idea.
I also recommend Filastruder for the spares, along with PrintedSolid, if you're in the US.
Posted : 30/05/2020 8:50 pm
spacebed
(@spacebed)
Hello all! So given how this year has gone, fixing this printer did not end up high on the priority list. But! I just got the thermistor in the mail a couple days ago and took a stab at replacing it. This is the part I ended up buying.
No matter WHAT I've tried, it absolutely will not fit inside of the heaterblock. Am I doing something wrong? The little screw that goes in below still threads just fine, despite what that might look like 🤣 .
I'm also willing to purchase a new heaterblock and whatever else I might need, and attempt to replace it all as suggested (I got cocky after getting the old thermistor out, heh), but was curious if someone would point me in the right direction with links if possible! I have faith I can get this working again, but I don't have faith in my ability to choose the right pieces to do so, haha.
I'm thinking the .4mm nozzle here is something I should be looking at, as well as this heaterblock?
Thanks y'all!
Posted : 13/11/2020 1:25 am
Try drilling the hole out...
Joan
Posted : 13/11/2020 5:26 pm
Kent
 Kent
(@kent)
Are there any articles on how to replace the entire hot end assembly for a MK2S?
Thanks!
This post was modified 5 years ago by Kent
Posted : 06/01/2021 6:20 pm
