My printer cant print
I have frustratingly tried to print something but neither my SD card is working or the USB
The SD card says it has been inserted but when i look it says no SD card found so i decided to print over USB as i could not find a way to fix the SD card
Printing over usb worked for about one print then 2 days later when i try to use it, Cura says that my printer does not show up please help me.
Napsal : 06/11/2018 4:36 am
Re: My printer cant print
Does your SD have a lock button? Make sure it's locked.
Also make sure you ejected it correctly from the computer before plugging it in.
Napsal : 02/12/2018 4:39 am
