Motor Specs for Duet Firmware Config Tool
Secretasianman7
(@secretasianman7)
I'm about to upgrade my MK2S with a Duet 2 Wifi Board.  I'm using their firmware configuration tool to create firmware for the board, but I need to know all the info relating to the stepper motors so I can input that into the tool.
The info I need for the X, Y, Z, and Extruder motors are: Microstepping (interpolation), Steps per mm, Max Speed Change (mm/s),  Acceleration (mm/s ^2), and Motor Current.
Where might I start looking for this information?  Or does anyone have this info on hand?
I have one last question, I'm making plugs for the stepper motors to connect to the duet board and I want to make sure I have the polarity correct before I go powering it on.  Looking at the markings on the Rambo board, it seems like the stepper wires are marked as such: Black=2B, Green=2A, Red=1A, Blue=1B.  Cany anyone else verify that I've got this correct?
Thank you very much for your time.
Respondido : 19/04/2022 10:27 pm
towlerg
(@towlerg)
RE: Motor Specs for Duet Firmware Config Tool
I'm surprised somebody hasn't already posted a config for a Mk2s.
Respondido : 20/04/2022 11:16 am
