Mk2s - assembled
william.b34
(@william-b34)
Mk2s - assembled
i have the printer now, but am having issues with it. it came in assembled, but as i am running thru the calibration process, it fails.
first, i started with the assembled instructions, but:
* pre-heat option was not working, so i could remove filament that it was shipped with
* i would pick PLA from list, but nothing ever got hot
so, i then tried to use the wizard, but:
* now i cant get past selftest/checking endstops/hotend:1
* once it gets to that point, it completely bombs out and tries to start all over.
Respondido : 10/04/2018 11:59 pm
alexander.s27
(@alexander-s27)
Re: Mk2s - assembled
Obviously the hot end does not get hot. Check whether the heat cartridge ist connected to the board tight and in the right place.
Respondido : 11/04/2018 5:52 am
alexander.s27
(@alexander-s27)
rob.l6
(@rob-l6)
If you just received it I would contact support first via the online chat.
Respondido : 12/04/2018 10:45 am
