Load fillament works well but it fails when I print
My MK2S loads the fillament properly, but when I start to print anything it doesn't extrude the PLA as it should. At the left of the photo you can see the extruded fillament. At the right, the one that extrudes when it is printing. A M3 bolt at the middle for scale.
I cleaned the extruder as it was new. I dissassembled all the extruding components, I cleaned it and I changed the PTFE tube as well. The control board seems OK.
I'm using the calibration gcode from Prusa but it also works bad with other gcodes.
I don't know what to try. I would apreciate any help. Thanks!
Postato : 29/05/2024 3:07 pm
