live z calibration not being saved
marko.m3
(@marko-m3)
After setting up the live z offset on my prusa mk2 it prints fine on the first print. But every print i have to add to my live z offset. so for example first print is -0.5 second print is -1.0 third print i need to set it to -1.5 and so on. For some reason the z offset doesnt get saved but it shows it as if it does. THis started happening when i moved houses.
I cleared calibration and re did a full xyz calibration - (passes)
I ran a self test (passes)
I have run the calibration gcode built within the os and updated my firmware to the latest available.
I use Prusa Slic3r to export my files.
Prusa Mk2S firmware 3.1.0
Rambo13a
Checked nozzle its firm
PID is secured firmly
any suggestions?
Napsal : 20/05/2018 9:53 am
Albe
 Albe
(@albe)
Re: live z calibration not being saved
Try letting the bed cool down before starting the next print. You probably have pinda readings changing due to temperature differences.
Napsal : 20/05/2018 10:27 pm
or, try moving your extruder to about 60mm before starting heating for every print...
the Pinda appears to be temperature sensitive
it gets hotter when heating for a print from a low level, which leads to inconclusive z height, and repeated adjustments make matters worse!
Napsal : 21/05/2018 12:04 am
