Left Hotend Fan Wiring Error
brandon.v3
(@brandon-v3)
Just got my MK2S and put it all together correctly. Went to get the wizard up and running and test to make sure it all good, apparently not since I keep getting this error.
I reflashed firmware, removed the connector and put back, tried cooling fan, everything. I checked if the crimping and connector good, idk.
It spins for a second, both fans tested, and then fails. If anyone else had this problem and found a solution that would be great to help me. I wanna get printing agian
Postato : 02/05/2018 6:58 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Left Hotend Fan Wiring Error
I think the firmware asks whether the fan is spinning, with "No" being the default - you need to select "Yes" before pressing the knob.
Peter
Postato : 02/05/2018 12:59 pm
