LCD display not working (First time startup, kit)
RakeMakes
(@rakemakes)
Hi!
I recently bought and assembled a Prusa MK3 kit. Everything was running smoothly until I plugged it in.
The LCD display flickers once and then nothing.
I've checked the cables to many times to count, and they are correct.
I tried adjusting the contrast of the display but nothing happened.
I flashed the firmware to the latest version but again; nothing.
I wore an anti-static wristband throughout the entire assembly (even with the plastic parts) so I am at a loss.
Anyone have any idea of what to do?
Here´s a video of what it looks like:
https://drive.google.com/file/d/1BsJ10tvvg5PTNrzozFXjCB37BX-YspnY/view?usp=sharing
Postato : 17/01/2019 10:16 pm
Re: LCD display not working (First time startup, kit)
Hi Erik,
First observation,
The video does not show a Mk2 Prusa, it shows a Mk3 you have posted in the mk2/s section of the forum.
on the back of the LCD board, there is a tiny trimmer resistor which adjusts the contrast, have you tried adjusting that, to see if it resolves your difficulty?
Postato : 18/01/2019 12:38 am
