Inverted z-axis after firmware update
oblende
(@oblende)
As the title says. I downloaded the newest prebuilt firmware and flashed it without issues, but when I homed the machine I discover that the z-axis is now inverted. Now, why did Prusa mess up the firmware like this, and what do I change in the source code to fix it?
Postato : 01/05/2020 11:53 pm
towlerg
(@towlerg)
RE: Inverted z-axis after firmware update
Wild guess - you have downloaded the wrong firmware for your printer.
Postato : 02/05/2020 3:05 pm
oblende
(@oblende)
As much as I wish it could be my fault, and usually is, I'm pretty sure it isn't this time. Just to verify the file name for the I3 MK2 is: prusa3d_fw_3_2_3_MK2_MK2MMU.zip, correct?
Postato : 03/05/2020 12:46 am
That would appear to be correct!
Postato : 03/05/2020 12:58 am
oblende
(@oblende)
Thanks for verifying, but that is also the problem. This is the firmware that I downloaded from Prusa's site, but the z-axis is now inverted. I reverted to the previous version of the firmware, and z-axis is acting as it should, but I'd really like to have the bug fixes in the newest firmware. I would really like to use either repetier-host or go full octoprint just so I can stop swapping the sdcard back and forth between the printer and computer.
Postato : 03/05/2020 1:44 am
Have a word with Prusa Chat, they may have a suggestion.
I am not at home at the moment because of lockdown. but I think I have this firmware on my Mk2 with MMUv1 ...
However I can't see how the Z motors would be different...
Extruders, Yes... 2 of the 4 extruders naturally turn one way and the other two turn the other way. if you accidentally wire them up 4,3,2,1 instead of 1,2,3,4... then all four extruders will run backwards! 🙂   (yes  I did that when I first built the MMUv1) 😀
Regards Joan
Postato : 03/05/2020 10:10 am
towlerg
(@towlerg)
@oblende
"As the title says. I downloaded the newest prebuilt firmware and flashed it without issues, but when I homed the machine I discover that the z-axis is now inverted. Now, why did Prusa mess up the firmware like this, and what do I change in the source code to fix it?"
I'm missing something here, poster makes no reference to MMU but uses firmware for MMU?
Postato : 03/05/2020 10:57 am
oblende
(@oblende)
The archive contains both the standard MK2 and MMU firmware in separate directories. Really this whole thing is strange.
Postato : 03/05/2020 1:27 pm
oblende
(@oblende)
I have some further information on this subject. The Z-axis is not inverted. What happens is that when it homes it goes positive Z instead of negative Z to find the bed. So it's an error in homing not a direction inversion. Sorry about the confusion. So what has gone awry and and what should I change to get proper homing behavior?
Postato : 03/05/2020 9:27 pm
towlerg
(@towlerg)
@oblende
Not wishing to flog etc. but do you have an MMU?
Postato : 04/05/2020 12:48 pm
