Infill not reaching left perimeter
Suddenly infill started to miss the left peremiter.
x, y pulleys are tight,
both belts are pinging
two different slicers produce the same result (Simplify 3D and Prusa controll),
what else could be causing this (infill not reaching outline)?
What else is the in the equation to consider?
If belts are not thighs or pulleys are slipping, then peremiter should not be straight, right? But it is. 😕
Napsal : 21/05/2018 1:47 pm
