HotEnd Temperature +/- 3°c
I wanted to know if the variation of plus or minus 3 degrees is normal even if the extruder is fixed.
If it's not normal do you know how to fix it?
Thank you 🙂
Edit : Its was temperature was set a 210°
Respondido : 09/12/2016 6:15 pm
Re: HotEnd Temperature +/- 3°c
Yes.
But you can get closed by adjusting the PID settings (search the forum...)
Peter
Respondido : 09/12/2016 11:28 pm
