Help replacing PTFE tubing on Hot End Nozzle
yancarlo.m
(@yancarlo-m)
So my filament went cold and got stuck within the hot end... After trying to pull it out from the top, the filament ripped. I tried cutting the PTFE top end but ended up yanking the whole white PTFE tube out of the hot end... Can I just replace the PTFE tube ? Or do I need a new hot end ? (btw you guys are out of stock on it, let me know if I can get it from someone else). If I can replace the PTFE, let me know what dimensions are appropriate (ID 3mm?).
Napsal : 12/12/2016 5:17 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Help replacing PTFE tubing on Hot End Nozzle
ID 2mm OD 4mm. Available in many places, but quality varies.
E3D: http://e3d-online.com/Bowden-Tubing-1.75mm?search=ptfe
Peter
Napsal : 12/12/2016 8:20 pm
yancarlo.m
(@yancarlo-m)
Thanks Peter : )
Napsal : 12/12/2016 8:56 pm
