Heatbed soldering
pierre.a2
(@pierre-a2)
Heatbed soldering
Greetings,
Please forgive my question, I tried to search but found nothing. Please also bear my terrible english...
A heatbed wire was broken on my MK2s. I tried to desolder it, however I can't achieve melting this solder.
At what temperature do I need to put my iron to desolder this broken cable ?
Thank you.
Opublikowany : 15/09/2018 10:57 pm
Re: Heatbed soldering
Hi Pierre
I use a 50 watt temperature controlled soldering iron with a chunky tip. set to about 350C,
I put the iron on the joint and add some fresh solder to begin the melt.
Your English is fine, far better than my French!
Opublikowany : 16/09/2018 9:56 pm
pierre.a2
(@pierre-a2)
Hi Joan,
Thank you very much ! I used an old 150W iron, and it worked.
Best regards,
Opublikowany : 17/09/2018 12:59 pm
