heatbed plug
michael.p12
(@michael-p12)
heatbed plug
hello any one know how to fix a new connector on to heatbed cable that fixes to Rambo board
plus what is that plug called.
thanks
Publié : 08/09/2018 5:51 pm
alexander.s27
(@alexander-s27)
Re: heatbed plug
Remove it and solder the cables directly onto the board.
Publié : 08/09/2018 5:54 pm
michael.p12
(@michael-p12)
Re: heatbed plug
a bit drastic. looks like the plug just unscrews
Publié : 08/09/2018 6:08 pm
michael.p12
(@michael-p12)
Re: heatbed plug
any one know what size plug please.think it maybe 5.08.but not sure
thanks
Publié : 08/09/2018 6:21 pm
alexander.s27
(@alexander-s27)
Re: heatbed plug
Drastic not at all, just reasonable and durable.
There are lots of threads around here about this conector. And still, once successfully replaced it most likely will melt again sooner or later...
Publié : 08/09/2018 10:56 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: heatbed plug
Best soldered. Otherwise you will have problems.
Just solder some tails to the board and use decent 20 Amp clip connectors.
Peter
Publié : 09/09/2018 7:22 pm
michael.p12
(@michael-p12)
Re: heatbed plug
OK THANKS
Publié : 09/09/2018 9:03 pm
Uli
 Uli
(@uli-3)
Re: heatbed plug
I had the same problem: melted connector. I also just soldered a piece of wire direct to the platine and it works very well. I then soldered the piece of wire to the heatbed wires.
If you want to have a removable solution I would suggest to use a pair of gold connectors. 2mm gold plugs would be sufficient. They are easy to get in hobby stores.
If quite a number of people have this problem, the developers should think about using another kind of connectors. I think the problem occurs because of the resistance of the connection.
Please excuse my bad english
Uli
Publié : 20/02/2019 5:17 pm
