Firmware Flashing Help Needed for Titan Aero
JJ3DPrinter
(@jj3dprinter)
My prusa I3 Mk2S hot end I ended up replacing as I snapped the heat-break because of the melted plastic mess from the nozzle loosening up overtime. I ended up tossing the hot end and threw a E3d titan aero. I printed this mount out on thingiverse and have the printer all wired back up along with an external mosfet for my heatbed.
https://www.thingiverse.com/thing:2192480
Now I download on prusa's site the zip file of the current firmware 3.1.0. I edited the Pinda Probe offset as the x-carriage mount changed the location of the probe in relation to the beds leveling points. I'm having issues with trying to compile the code and flash it back onto my prusa i3 mk2s.
I've used TH3d firmware tool package in the past for my CR10S5. I opened up the prusa fimware INO file with arduino 1.8.5 which came with the TH3d firmware tool package. I made my changes to the configuration h tab up top. Then I selected my board type RAMBO on com 3 port and tried compiling and got the message "Error compiling for board RAMBo."
Any help would be appreciated if you could point me to a video or site with directions that I can follow.
Opublikowany : 11/12/2018 11:57 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Firmware Flashing Help Needed for Titan Aero
Just follow the instructions: https://github.com/prusa3d/Prusa-Firmware Scroll down a bit to your O/S.
Peter
Opublikowany : 12/12/2018 10:09 am
PJR
 PJR
(@pjr)
You may also need to follow these instructions: https://github.com/prusa3d/Prusa-Firmware/tree/MK2
Peter
Opublikowany : 12/12/2018 10:11 am
JJ3DPrinter
(@jj3dprinter)
Peter
Thanks, I followed your link and was able to upload my printer changes. Unfortunately my changes to firmware 3.1 don't seem to work properly as the pinda probe isn't probing the proper locations on the heated bed. The provided firmware on the thingiverse page is 3.0.10-6 and there are some things that don't work properly for my setup. One of these being the extruder being geared needs to have the direction inverted in firmware which I planned to do. The other option was for me to reverse the wiring which I don't want to do. I thought about just putting a negative sign in front of my e-step value and with M92 but that didn't seem to work. The pinda probing spots on the bed are accurate with his firmware so I'm likely modifying the firmware's values not properly.
Thingiverse Titan Aero Reference
My Changes to firmware will be in Next Post
Inverted E1 Extruder to False
Pinda Probe Offset
Opublikowany : 15/12/2018 5:47 am
JJ3DPrinter
(@jj3dprinter)
Manual Home Position
WHERE IS TRAVEL LIMITS AFTER HOMING?
Or ?????
I flashed the thingiverse .HEX firmware and like I said the probing points are correct. Is there a way for me to read this Hex file or pull it off my Rambo board so I can compare the values in his firmware with my failed attempt at updating Prusa firmware 3.1 version with the stated changes stated on thingiverse?
Opublikowany : 15/12/2018 6:01 am
