Firmware flashing fails: stk500v2_command(): command failed & verification error; content mismatch
jeroen.v7
(@jeroen-v7)
I changed some parameters in the firmware for the i3 MK2S but it won't flash to the printer. Below the avrdude output log:
avrdude: Version 6.3-20160220-prusa3d, compiled on Aug 30 2018 at 16:11:16
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "E:/PROGRA~1/Prusa3D/Slic3rPE/resources\avrdude\avrdude.conf"
Using Port : COM3
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: safemode: hfuse reads as D0
avrdude: safemode: efuse reads as FD
avrdude: reading input file "E:\Downloads\Prusa-Firmware-MK2\Prusa-Firmware-MK2\Firmware\Firmware.ino.with_bootloader.rambo.hex"
avrdude: writing flash (261406 bytes):
avrdude: stk500v2_command(): command failed
Writing | ################################################## | 100% 43.24s
avrdude: 261406 bytes of flash written
avrdude: verifying flash memory against E:\Downloads\Prusa-Firmware-MK2\Prusa-Firmware-MK2\Firmware\Firmware.ino.with_bootloader.rambo.hex:
avrdude: load data flash data from input file E:\Downloads\Prusa-Firmware-MK2\Prusa-Firmware-MK2\Firmware\Firmware.ino.with_bootloader.rambo.hex:
avrdude: input file E:\Downloads\Prusa-Firmware-MK2\Prusa-Firmware-MK2\Firmware\Firmware.ino.with_bootloader.rambo.hex contains 261406 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 29.92s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x3c000
0x00 != 0x90
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK (E:FD, H:D0, L:FF)
avrdude done. Thank you.
I used the Arduino IDE environment with RAMBo board selected and Slic3r to flash the FW. Hope someone knows how to resolve this. thanks!
Opublikowany : 13/09/2018 1:41 pm
