Faulty motor control - Control board or power issue?
ge93
 ge93
(@ge93)
My MK2s is failing to extrude and unload filament properly. The extruder motor stutters when trying to unload filament, and only functions smoothly at low rpm (e.g. manual extrude/retract via octoprint).
The problem doesn't seem to be the stepper motor; I connected a z axis stepper to the extruder socket and the same problem occurs (see video). Does this suggest there is a faulty control board or power supply?
Thank you in advance
Ce sujet a été modifié il y a 5 years par ge93
Publié : 27/03/2021 2:38 pm
